Posted 8/31/2010 7:34:36 PM |
Last Login: 1/13/2024 9:34:39 PM
Visits: 833
Hello,
I was wondering if anyone has any ideas on where to locate the body in relation to the chassis. Should it be at the same level as the lower edge of the frame, upper edge.......?
Dave B.
Posted 11/10/2013 10:09:07 AM |
The cake is a lie.
Visits: 513
This is a late one (but, better late than never). It all depends on the type of chassis and suspension set-up. I know if you're going to be running air-bags and using a stretched latter frame from, say a 1996 Impala or Caprice than the bottom of the body should then be in line with the bottom of the frame. If I remember correctly there should be 1-1.5 inches of clearance on either side between body and frame.
