Posted 4/21/2011 7:30:57 PM |
Got no time to bleed!
Last Login: 2/8/2019 4:13:31 AM
Visits: 216
I totally redesigned them for wheel standing if possible, also pitched them out to allow for sharp turning, and laid back the king pins to allow the tires to return to center after turning the vehicle. Does batman do wheelies? LOL. I have a lot of pictures of the progress , getting a lot done now, Have the inner panels around the nose and inside the front claws done, also the top trim panel in the upper window areas, I have the inside aluminum panels cut for cockpit area installation. Rear suspension is now ready for final welding, I didn't have it attached in all the previous pictures. Motor mounts will be next and only then can I design the rear wings.
Posted 1/26/2012 5:29:55 PM |
Last Login: 1/26/2012 5:54:35 PM
Visits: 6
Any updates with your awesome built?
Posted 4/12/2012 8:44:59 PM |
Visits: 216
back at it again, I know I am a little slow but always building on something. Here is the rear spring I installed last Saturday.
Posted 4/12/2012 8:48:41 PM |
Visits: 216
The car is setting on her own springs now.
Posted 4/12/2012 8:58:16 PM |
Visits: 216
shock next on the list
Posted 4/12/2012 9:01:21 PM |
Visits: 216
Here is the sides for the nose next time front steering column
Posted 8/7/2012 9:24:24 AM |
Last Login: 3/24/2024 12:45:26 PM
Visits: 1,029
Hows that steering column coming?
The will to act.
Posted 8/17/2012 10:28:40 AM |
Visits: 216
sorry been away for a while, moved on to more body parts , like the side lower wings, and the inside floor and bulk heads, all of which are aluminum. I will have some pictures to follow.
Posted 9/16/2012 3:10:52 PM |
Visits: 216
Building small part again, I know I'm slow but Rome wasn't built in a day
Posted 9/16/2012 3:12:07 PM |
Visits: 216
Small upper window corners made
