Posted 1/26/2012 5:00:27 PM |
Last Login: 6/19/2023 1:55:12 PM
Visits: 897
Machings Guns coming together...
Posted 1/26/2012 5:57:26 PM |
Visits: 6,742
AWESOME, very clean fab
Posted 1/26/2012 6:25:23 PM |
Last Login: 12/22/2023 6:10:02 AM
Visits: 1,033
Posted 1/27/2012 7:26:59 AM |
Very nice! I like how you dropped the actuator down along the side of the frame to get the height you needed
On my car, I've found that when they run parallel with the frame, the guns look like they are tipped down just because the body of the nose rises.
I'm going to tilt mine back a bit
Posted 1/27/2012 9:54:25 AM |
Visits: 897
brcewane (1/27/2012)
Very nice! I like how you dropped the actuator down along the side of the frame to get the height you needed On my car, I've found that when they run parallel with the frame, the guns look like they are tipped down just because the body of the nose rises. I'm going to tilt mine back a bit Hey Tim, We had the same problem... However, when we did the final welding we raised the front lower bracket up about 1/2 inch off the frame...it made a huge difference. I'm a fan of your work, looks like your coming along really good.
Posted 1/28/2012 2:23:49 PM |
akajunk (1/27/2012)
Hey Tim,
What a simple solution!! I didn't even think of that.. I would have gone out and tried to angle the top on the sliders. You just saved me a day of work
Posted 1/28/2012 11:34:20 PM |
Visits: 3,900
Posted 5/18/2012 10:37:13 AM |
Visits: 897
Not much progress, However some new pictures.
Posted 5/18/2012 1:29:40 PM |
Visits: 3,119
Nice pair
Well I'm assuming there is two of em. I can only see the one....gun i was looking at the gun
what did you think I was referring too?
I'd like to see more...... Ok now I'm referring to her....#!#$..
Later
333 HALF EVIL
Posted 5/29/2012 1:25:56 PM |
Last Login: 8/31/2012 10:19:27 PM
Visits: 172
Is that a rear mounted camera above your thruster vent?
