Posted 7/16/2009 4:59:41 PM |
wahoo! i got meantioned ^ lol
Posted 7/16/2009 5:26:31 PM |
Last Login: 2/27/2024 5:15:30 AM
Visits: 171
Yep! Top job on the cad drawings. I thought I was going to have to buy one of the hot toys models to get anything remotely close to what you have done. I will be buying one too, but your drawings would make such a difference. I have quite a few qns about the pod, should I start a new thread or put them here? First one is about the steering. The outer gun pod on the front wheel I assume is fixed through the centre of the hub? I was planning on using a car type hub and attach a shaft into the hub centre for the gun pod to fix to. It will definetly be a weak point, but should work. Should the inner gun pod be attached to the hub too? Not sure on this as if it is attached to the swingarm it will pivot differently to the gun pod on the other side. So many qns!! Sorry! Ideas on hydraulic operated steering and loads more!! Who decides when someone has contributed enough to join? Drew
Posted 7/16/2009 6:52:09 PM |
Posted 7/17/2009 7:55:13 AM |
Visits: 171
Thanks, much appreciated. Just posted a few of my ideas through there re:the drive train etc I had almost given up on making a pod even after doing so much research, but stumbling on this site has really given me a boost! I will make sure I give shaggy recognition on anything of his I use. Cheers
