Posted 10/17/2008 8:32:52 AM |
Drew, that was done up in SketchUp, it took me about a month's time on and off, a few hours here, and there. Thats what i like about the 3D work, if you screw up, or if you find something off scale, delete it and start over, OR sometimes easily modify what you already have exhisting. . This way i built my paper model one time complete and had no off scale parts, the 3D work checked all that for me ahead of time.
Posted 10/21/2008 11:58:15 PM |
Last Login: 5/20/2009 9:58:26 PM
Visits: 161
I finally figured out how to get the pictures off my camera. sept 27
Posted 10/21/2008 11:59:08 PM |
Visits: 161
oct 4
Posted 10/22/2008 12:00:26 AM |
Visits: 161
some time after that
Posted 10/22/2008 12:05:36 AM |
Visits: 161
and now to now.
Posted 10/22/2008 12:09:02 AM |
Visits: 161
this sure makes the joints look bad... ill remove the extra solder before attempting to add panels to it
Posted 10/22/2008 12:11:25 AM |
Visits: 161
from the top... the front arms actually line up. this pictrures a little misleading about that
Posted 10/22/2008 12:17:15 AM |
Visits: 161
these brass rods are great. theyre just soft enough to bend, and they don't bend unintentionally. they're perfect medium to make a small model out of. and i realized adding the other 9" worth in scale would be no problem. i was actually squished in the legnth of the "cab" area, so it turns out to be a good thing i messed up.
Posted 10/22/2008 12:30:26 AM |
Visits: 161
now here is my next problem: i dont know the shape of the that piece and i cant find a picture of the actual batmobile that i can firgure it off of. Does anyone have any ideas? I was wondering how this piece would affect the panels when i try to put them on. the way it is currently i think it'll be a hinderance. I'm thinking it must be bend inward. does anyone know?
Posted 10/22/2008 8:20:19 AM |
first off, excellent job! i visualized what that set up would be like with panels, and i honestly didnt see any hinderance from your set up so far. As far as that peice goes, it technically wasnt on the original, BUT i dont see it messing you up as far as panels, might actually assist with support.
