Turbine Frame
«««1234
Turbine Frame Expand / Collapse
Posted 5/2/2006 7:49:24 PM
Last Login: 2/18/2020 6:16:09 AM
Posts: 2,309, Visits: 8,740
I had thought using a puller cooling fan behind the aircraft fan blades to keep the turbine fan blades turning continually.
Post #47703
Posted 5/2/2006 7:53:30 PM
i think that would work.....i figued by the time i have the cone and bars with the fan turned around backwards it will look pretty close...
Post #47704
Posted 5/2/2006 7:57:41 PM
I did have a contact for turbine fan blades in the southern area, but I am unable to make contact with him. I did hear that he was planing on moving up north.
Post #47705
Posted 5/2/2006 8:02:29 PM
how did you make your tri bars....jacks turned out good with the pipe.....and nitros tuned out good with (the real thing you sorry dog)...
Post #47706
Posted 5/2/2006 8:16:47 PM
Haven't done that yet, still preping the body. I will be off from work Wednesday through Friday so I will try to get more done. I am almost ready to prime the front half of the car.
Post #47708
Posted 5/9/2006 1:53:49 PM
Useless Forum Member
Last Login: 8/18/2013 12:16:26 AM
Posts: 402, Visits: 1,909
So that's where my giant pot went!
On another note, Kev, that is freakin' sweet.  I have to admit, I would have never come up with fryer pot housing myself.  +3 MacGyver points for you mate.  And are you planning on painting it?  Because I think it would look sweet as it is, but you car, your choice.
Right on dude!
Cheers from down here!
Live life to the Max!
Post #48229
Posted 5/9/2006 4:57:46 PM
I was looking for something for over a year that was the right diameter with a lip and the diameter was the same from top to bottom.
Now I need to cut it down to the right length of 8" and install the blades. Jack needs to make me up a set of mount points and struts to go with my turbine section!!
Post #48247
«««1234
All times are GMT -5:00, Time now is 8:01pm
