Turbine Frame
««1234»»»
Turbine Frame Expand / Collapse
Posted 4/24/2006 6:15:11 PM
Last Login: 6/9/2008 1:31:33 PM
Posts: 60, Visits: 695
Sorry if this has been asked elsewhere. Where'd ya get it!?
Post #47516
Posted 4/24/2006 6:41:40 PM
Nice Kevin your going to hate to paint it.
Post #47517
Posted 4/24/2006 8:11:15 PM
Last Login: 8/20/2023 5:58:56 PM
Posts: 2,343, Visits: 8,989
I used an aluminum cooker because it has a nice lip and it remains the same diameter through the bottom of the can. Unlike most cans that taper to the bottom. It was also the right diameter, took me forever to get the right one.
Post #47518
Posted 4/24/2006 8:15:45 PM
It looks tappered, have a side shot?
Post #47519
Posted 4/24/2006 8:38:13 PM
Here you go Jack, I think it will look great when it is done, I can send it to you and I will let you build it up for me, yes?
Post #47520
Posted 4/24/2006 8:55:46 PM
Sorry, I can’t weld aluminum. Or it stainless? I can’t weld stainless either except by mig, but then it would have to be painted. How are you going to fit the blades far enough back to allow for the center section or does it just appear that it’s too tight for the blades to go deeper in?
Post #47521
Posted 4/24/2006 10:52:55 PM
The blades will drop all the way to the bottom the basket is holding them up. I will need to shorten the housing and remove the handles.
I use alumiloy welding rods with a regular butane torch to weld aluminum and it works and looks great.
Post #47522
Posted 4/25/2006 5:22:43 AM
Good deal can't wait to see it. It should look awesome.
Post #47523
Posted 4/25/2006 7:56:27 AM
But if it doesn't work out, we can all have deep fried turkey!
Post #47524
Posted 4/25/2006 9:13:59 AM
KITT For Now
Posts: 382, Visits: 960
Post #47525
««1234»»»
All times are GMT -5:00, Time now is 10:35pm
