Posted 7/25/2006 10:28:01 AM |
Visits: 2,210
wow, I don't know what planet sells enough resin for a tumbler for 300 bucks. In fact with the tumbler, you are actually doing at least TWO batmobiles worth of resin, i.e. about the eq. of two 89 bodies. not joking. You have a sort of underbody, then you have all the components on top of that, then throughout, you have some of the upper components running partial underneath each other. Lotsa footage to cover. Huge wheel base, wide as hell. I can tell you this: when you build a car like a tumbler, or 95' car from scratch, you give your SOUL to it. The most expensive item.
Posted 7/25/2006 11:19:13 AM |
I don't know how you did it. Building the Tumbler must be like building a puzzle one piece at a time and then putting it together. And it looks like it all fits together perfectly! It's beautiful. You should have your own thread in the build logs for your comments on the project.
Posted 7/25/2006 11:45:50 AM |
KITT For Now
Visits: 960
Tim (7/25/2006) You should have your own thread in the build logs for your comments on the project.That's a great idea actually!
Posted 7/25/2006 2:51:51 PM |
Visits: 2,210
Posted 7/25/2006 3:17:17 PM |
KITT For Now
Visits: 960
I could start you a new thread in the Build Log section, but it'd probably be better if one of the mods could the part of the "Tumbler build pics" thread over to it so you have the stuff you've posted as well as the responses. If I just copied and pasted what you've posted and not what other people are asking, it just wouldn't make as much sense.
