Posted 11/28/2005 12:12:28 AM |
Visits: 678
HEY JACK GOOD ENOUGH
COME TO THE MARKSIDE
Posted 11/28/2005 7:52:35 AM |
GOOD ENOUGH? Hell no!!!
I like it, I like it a lot. Great work Mark. As the critic I am I do have to add my 2 cents. Everything excet the rad hose ends and the water neck look great. Redo that end and I think you'll have a winner. Clever use of "of the shelve" parts. I was thinking about using header flanges too. Thanks Mark and hey nice Pudding!!!
Posted 11/28/2005 9:58:03 AM |
Last Login: 5/8/2023 12:22:24 PM
Visits: 1,020
SWEET!
Posted 11/28/2005 10:29:22 AM |
Visits: 421
Way better than the fiberglass side mechanics.... way better.
_______________________________________________ When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Posted 11/28/2005 11:01:25 AM |
Visits: 3,239
Awesome! I am impressed.
Posted 11/28/2005 11:04:07 AM |
Last Login: 11/8/2023 2:11:16 AM
Visits: 5,469
Mark does it again (posts proof ).
You the MAN Mark.
Posted 11/28/2005 12:32:46 PM |
KITT For Now
Visits: 960
So what did you use for the "bolted together" area? Sculpt that was casted? Found part? Trade secret? Great job!
Posted 11/28/2005 1:02:53 PM |
Visits: 678
THEY ARE REALLY BOLTED TOGETHER ITS THREE PIECES I SCULPTED THEM AND CAST THEM MY SELF(THE ALUMN I HAD WATER JETTED DID NOT LOOK RIGHT AFTER I PUT THEM TOGETHER)..AS FOR THE LEFT END I USED THE WATER NECK BECAUSE OF AVAILIBILTY THE TWO INTO ONE PIECE I DIDNT WANT TO SPEND THE TIME TO SCULPT ANOTHER ONE IT TAKES TO MUCH TIME AWAY FROM DRINKING RIGHT NOW MAYBE LATER
Posted 11/28/2005 1:13:02 PM |
Visits: 1,020
For sure the proof is in the pudding.
Mark,
What material did you cast your sculpt in? Did you actually cast the parts yourself of have a foundry do it? (if they are metal) The bolted up components look to be aluminum.
Is it fiberglass dusted with aluminum??? You did an awesome job, just trying to figure out how exactly you casted the parts.
Thanks for the info & the excellent work!
Posted 11/28/2005 6:19:15 PM |
Yep I like it.
