Lifesize Batman TAS Batmobile
«««12345»»»
Lifesize Batman TAS Batmobile Expand / Collapse
Posted 7/24/2005 6:40:31 PM
Last Login: 10/6/2023 7:42:26 AM
Posts: 2,343, Visits: 8,990
I thought it was a single seat version, the toy is?
Post #33502
Posted 7/24/2005 7:59:36 PM
I remember Batman having passengers in the cartoon.... I am sure they will be a little more cramped than in the '89 though!
Post #33503
Posted 7/24/2005 8:52:40 PM
I would want to widen the center section to allow the cockpit to be larger. You would have to do it the entire lenght of the car to make it look right. Not widen the entire car just the hood, canopy and the area behind the canopy.
Something like this.
Post #33504
Posted 7/24/2005 9:08:13 PM
Last Login: 3/19/2014 12:18:48 AM
Posts: 181, Visits: 250
id say the front of the car is about 76" wide,
1' on each side to the raised center, that gives the cock pit area about 4'4" the back id say is about 8' that makes it stand out about 10" on teh side
Post #33505
Posted 7/24/2005 9:10:16 PM
ok i just noticed it angels in towards the back so change the back to about 12" on each side, keeping the back at 8'
Post #33506
Posted 7/24/2005 9:11:30 PM
plus the orginal so form the back outter edge to the center about 22"
(sorry for the last 3 diffrent post just noticed the edit post buttion)
Post #33507
Posted 7/24/2005 9:40:58 PM
I think it could be done using most of the 89's measurements including the cockpit. Maybe RJ can work up a 1/4 scale in his spare time.
Post #33508
Posted 7/24/2005 9:57:04 PM
Posts: 256, Visits: 678
OK OK OK ITS SIMPLE YOU HAVE ONLY ONE QUESTION TO ANSWER FOR YOUR SELF WHAT SIZE RIM DOES THE CAR HAVE THEN SCALE THE REST OF THE CAR FROM THERE REMEMBER RIMS ARE 2 INCHES BIGGER THAN THE CALL SIZE FOR INSTANCE A 15 INCH RIM MAESURES 17 ON THE OUT SIDE OF THE LIP WHEN I WANT TO SCALE A CARS LIKE THE MACH 5 I PUT A PICT UNDER A WALL PROJECTOR THROUGH IT UP ON A WALLUNTIL THE RIM SIZE IS WHAT IM AFTER THE DRAW IT ON LAYOUT BOARD AN AND GET CORRECT MEASURMENTS FROM THERE
COME TO THE MARKSIDE
Post #33509
Posted 7/24/2005 9:59:00 PM
YEAH I KNOW THROUGH SHOULD BE THROW NOT GOOD AT MULTI TASKING
Post #33510
Posted 7/24/2005 10:04:30 PM
im gonna do a 1/4th mdoel for ever car i build so when i get to building the tas batmobile the 1/4th will come fist and im sure it will go a lot faster then the 89 lol.
thing i hate about making items form a cartoon, is u can scale up one picture then antoher and get 2 totaly diffrent meaerments,
Post #33511
«««12345»»»
All times are GMT -5:00, Time now is 2:54am
