Frame stretch info & support
Frame stretch info & support Expand / Collapse
Posted 9/19/2021 8:00:17 AM
Posts: 169, Visits: 678
A few months ago, I was debating if I should DIY the frame stretch, now I can weld but i have the bare minimum experience with that, and definitely DO NOT feel comfortable taking on the frame. So I have been in the garage, practicing my cutting, welding, and etc on random scraps (just in case my balls drop haha). I have received an offer from a hot rod shop that does these kinds of jobs all the time, and I accepted it, but they were a few months out from taking on the job. In the mean time, I thought I would keep learning, and researching methods on how to do it, basically got to the point where one of these guys was just like.....dude dont over think it. You measure, you cut, you measure again, install, measure again, weld, and measure haha.
Anyhow, I thought I would share some of the links to the fab shops that do this type of work on youtube.
I must say I like the "Boxing the frame" method over using the plates, it seems like a lot cleaner of a look for those that plan to go the "full legal" route where the state inspectors will have to inspect your work.
Boxing the Frame
https://youtu.be/YmBQHkfcV9Y
frame boxing, tips and tricks.
https://youtu.be/q4W1jMAzQGc
How I cut and spliced the frame on the 4 door bronco diesel converstion
https://youtu.be/a17ghKf_-Kc
Extending / Reducing an S10 Frame
https://youtu.be/dDlE7t2_O7A
Backyard Frame Repair: Fixing a rusted/cracked truck frame
https://youtu.be/vXKGeiXAOWU
Hope these help....enjoy.
Post #169735
Posted 9/19/2021 11:43:00 AM
Posts: 1,684, Visits: 5,332
+1 on that brother.
Post #169736
Posted 10/9/2021 9:28:17 PM
Last Login: 1/23/2024 7:24:24 PM
Posts: 25, Visits: 121
Good content here! there are a lot of helpful welding videos on the youtube channel Weldingtipsandtricks.
Jodi has a lot of experience and goes through and into detail on the various welding techniques and practices. I'm a welder.fabricator by trade, and i would definitely recommend his channel
- Josh
Post #169781
Posted 10/20/2021 8:06:58 PM
Joshthefabricator (10/9/2021)
Awesome, Ill check out that channel asap. I really need to step it up with the welding, its costing me a small fortune having to sub it all out...FML.
Post #169847
All times are GMT -5:00, Time now is 5:35am
