Last Login: Today @ 7:05:25 PM
Visits: 694
this just in ....which I am very happy with.
Last Login: 2 days ago @ 2:27:04 AM
Visits: 593
Nice! I picked up one about a week ago (after weeks or searching). It was used but still in great shape.
Brian - Knightdriver
Visits: 694
Hey Brian,
yes this one is used too. It actually looks better than how it appears in the photo. But its a good "worn in"...kind of like a well worn leather jacket. I asked the person I bought it from if there was any known history, what it came off of etc., but no replies.
Last Login: Yesterday @ 8:11:38 AM
Visits: 5,285
Mountney manufactured a lot of steering wheels, steering wheel bosses and car accessories in different designs. They were intended to be used for mainly 'classic' car restorations/replacements. They are still in business today.
Link: https://www.mountneyclassic.co.uk
Visits: 694
Calipers loaded up....now I am at a stand still of sorts waiting for the M/T front tires....on back order til Dec!
Visits: 694
Well, while I'm picking my nose waiting around for the front tires to arrive, I figured I would poke around at something else. This "turbine" for starters which had the blades screwed to the cone....
I put a bearing on both sides of the center blade assembly ...
This is just mocked up but it spins freely now. Using the old front stab bar end link sleeve which I will cut down to size and get a shorter bolt.
Will eventually use one of the donor car door window motors and hook it up to turn it via switch in the cockpit...
Visits: 694
peeling the donor car steering wheel......
I'll cut out the center, and re-use the donor car steering wheel hoop to be the exit end of the burner can. Will re-use the center spline and make a steering wheel hub for the mountney.
Visits: 5,285
16 "steering wheel? The turbine housing is 16".
Visits: 694
Appreciate the info Mr A.
I found a burner can diagram some where on here that showed the front diameter at 21.42" and the rear at 13.88"
Visits: 694
Can anyone confirm dimension data for the burner can?
...in the meantime mocking up the can frame..
