Last Login: 6/25/2022 8:23:57 PM
Visits: 706
Well something knocked me out of commission for about 2 weeks. But finally back at it. Got all of the the front suspension removed. Will do the same seal treatment to areas I won't be able to access once the suspension is back in. I plan on re-using the stock spindles and stock sway bar - its pretty hefty. Going with tubular control arms, new tie rods, idler, center link, rotor. Thinking I may just have the steering gearbox rebuilt. Maybe spring for some wilwood calipers...
Last Login: 6/30/2022 7:39:51 AM
Visits: 4,777
Glad to see you back to work brother.
Visits: 706
Thanks Slysnake. Appreciate that. I can't believe how restless I get when I can't work on the thing. It's so consuming.
Visits: 706
Front end is cleaned up...
Visits: 706
Visits: 4,777
hahaha....... OK, you're going to have to explain that one.
Visits: 706
yes sir...
Visits: 4,777
Ha! Creative.
Visits: 706
Sealed up some of the front areas...
and cleaned up some of the factory parts that will be re-used.
And then.....yes the build continues....
Last Login: 6/27/2022 5:02:15 AM
Visits: 5,298
Trying to figure it out. Nose cone?
