Posted 8/3/2021 7:17:36 AM |
Visits: 678
Yes, this is a common issue. But from what I seen here on the forums is that most builders align the body to the front wheels and adjust the body kit to the rear wheels…..cut and patch type of thing. If you did through peoples build pics you will see what I’m talking about.
Go on and read brcewane’s blog, its super informative, and I must have gone through it more than a dozen times. Ill be doing a build myself and will be going through the same thing, but there is plenty of research here and help if you need it.
