Visits: 678
I’m curious if you guys have any ideas on what to do with a 2000 Yukon donor car, I just got this and trying to think if I can make something out of it....Any ideas?
Last Login: Yesterday @ 10:50:04 PM
Visits: 5,044
There is a guy here (not me) is using a Dodge truck for his DOJ Batmobile build. Your car could probably be converted to that as well if you're creative.
Visits: 678
slysnake (5/14/2019) There is a guy here (not me) is using a Dodge truck for his DOJ Batmobile build. Your car could probably be converted to that as well if you're creative.
That sounds interesting, Ill take a peek. Never even considered the DOJ Batmobile ha, I wonder if its a more invasive build then the others....probably.
Visits: 5,044
I wonder if its a more invasive build then the others....probably. There's not nearly as much information out there as there is on the '89 or Tumbler. So people doing this are breaking new ground.
Visits: 678
slysnake (5/15/2019)
The great thing is there is a lot of awesome builders on here that I could ask for help, the bad thing is I wouldn’t know even where to start haha.
Last Login: 2/28/2022 3:20:59 PM
Visits: 830
This chassis and drivetrain is a decent starting point for a snydermobile... my chassis design is specd out using a Hummer H2 rear end and making up new 4 link style arms, and the yukon/tahoe/burban run a similar style rear end configuration to the hummer... h2 is just a touch wider axle.
Visits: 678
THEMAN (8/23/2019) This chassis and drivetrain is a decent starting point for a snydermobile... my chassis design is specd out using a Hummer H2 rear end and making up new 4 link style arms, and the yukon/tahoe/burban run a similar style rear end configuration to the hummer... h2 is just a touch wider axle.
Have you started this project yet?
Visits: 5,044
Yes, this project is in progress. THEMAN and I have teamed up with him doing the mechanical stuff and me doing the body work. Hope to have a drivable car by summer or fall even though it will not be complete yet. Check our threads in the DOJ section. here's a sample of my body work:
Visits: 678
slysnake (12/22/2019)
Holy cow, that looks bad a$$ so far.
Ill check the DOJ section right away.
Visits: 5,044
Thanks brother. I'm stuck on a desert island right now, but I can't wait to get back to work on it. Looking at the end of June to pull the body out of the mold.
