Stretching the frame?
Stretching the frame? Expand / Collapse
Posted 2/5/2019 9:54:39 PM
Last Login: 4/10/2020 10:09:42 PM
Posts: 117, Visits: 417
I notice a few different frame stretch styles after going thru a few peoples build logs, some cut on an angle and weld together, others cut straight, and others cut straight and add a plate in the middle.
I’m new here but curious if you guys are just winging it with what works best for you? Or are you following someone else’s build instructions or?
Post #162702
Posted 3/1/2019 6:42:16 AM
Last Login: 2/10/2020 6:39:12 PM
Posts: 154, Visits: 596
Minijokerguy,
Preferred method is to angle cut the splice (@30 degrees to maximize the load bearing surface) and add reinforcement plates on either side, top and bottom with staggered plug welds.
One thing I often see in builds that require welding is the lack of the use of a weldable primer. Always a good practice to include some corrosion control when working with bare steel, especially when the back side could be partially encased, but still potentially susceptible to the elements.
Zeus
Zeus
Bat-what?.....Na, it’s just an oversized badass black car (with optional machine guns)
Post #162780
Posted 3/6/2019 8:53:34 AM
Last Login: 3/6/2019 8:45:12 AM
Posts: 1, Visits: 1
hello
I am mark jolly. I am a writer
just create my account
____________________
web development company in jaipur
Post #162792
Posted 4/10/2019 10:28:34 PM
Zeus Wayne (3/1/2019)
Minijokerguy,
Zeus
Not sure if its the same thing but instead of weldable primer, cant one just use a rust/metal encapsulator? I have used these before when working on shipping containers, its can be used as a primer or as a encapsulator for areas that are already affected by damage and or current elements hitting the metal.
Post #162940
Posted 4/10/2019 10:30:06 PM
Minijokerguy,
Zeus
Also yeah the angle cut splice seems to be a favorite around here.
Post #162941
All times are GMT -5:00, Time now is 7:21am
Execution: 0.078. 11 queries. Compression Disabled.
