Posted 3/19/2019 12:00:18 PM |
Visits: 845
yeah man... I thought the same until I respec'ed everything around them.
Posted 3/19/2019 12:53:39 PM |
do you think the enclosure around it is from something or custom?
Posted 3/22/2019 10:03:10 AM |
Visits: 845
good question... I haven't found the something yet if it is. I have some avenues to pursue soon to hopefully find out some answers on more of the exterior development.
Posted 3/27/2019 4:53:46 PM |
I ordered the clutch cover from Motostrano in January. They just called and said they can't get it. I have also struck out everywhere else I've tried. We're going to have to reproduce the part somehow.
Posted 4/1/2019 10:12:42 AM |
Visits: 845
Are you talking about the ducati clutch cover or the crank case guard for the steering wheel?
I have a clutch cover here, and intend to replicate it for use where needed... And can also do the same with the steering wheel hub aka crank case guard.
Posted 4/1/2019 11:34:20 AM |
Posted 4/1/2019 7:45:32 PM |
What do you think about 35X12.5R15 Mickey Thompson Baja Claw Radials for the front tires?
Posted 4/2/2019 6:18:40 PM |
Visits: 845
I would love then if they still made them in 20s... but unfortunately in talks with MT they destroyed the molds for that size, and moved a different style tire into that slot.
The 15s would look way off from the rear 20s on the wheel side of things... the ratio is too far different.
I'd go with something that gives a similar feel to the actual tires... I think I'm leaning towards these.
or
Posted 4/3/2019 10:45:52 AM |
yeah, those would work
I like the bottom one better. What is it?
Posted 4/3/2019 9:03:07 PM |
Visits: 845
RBP REPULSOR is the bottom one... even has a bulletproof sounding name.
pretty cheap.
https://www.amazon.com/RBP-Repulsor-All-Terrain-Radial-Tire/dp/B01M6WHNCQ/ref=pd_lpo_vtph_293_lp_t_3?_encoding=UTF8&psc=1&refRID=WF61J5A6ASR390R6MPBF
but probably not as tough in reality as the kumhos that are only $50 more per... should be ok for street driving though.
