sly's BvS DOJ Build
«««2021222324»»»
Posted 11/4/2017 9:39:14 PM
sly
"Do you think Hot Toys or Soap studios will ever release these to the public? I'm dying to buy one. There was also a Mezco one. Not sure if that is a different company than Hot Toys or just a different name. "
Soap Studios took pre-orders for 1300.00 that closed at the end of 2016.
Wrote Hot Toys representative and he said the 1:6 DOJ / Justice League will be produced but that it may well take a different final configuration and probably won't be available until near the release of the Batman stand alone movie sometime a month or two before the movie release.
Current expected price is ranged some where between 1500 and 1800.00. vertigo
Post #159810
Posted 11/20/2017 2:08:10 PM
vertigo (11/3/2017)
Found a few hours today to examine my Mattel 1:10 scale RC Justice
League Batmobile.
Upon opening the box one is immediately struck by the presence, sharp
lines, and details of this Justice League vehicle. Just on these looks
alone the 250.00 price tag seems very reasonable.
I have no regrets on this purchase.
Took some measurements of the vehicle. Starting with the Batman figure
that measured 6-1/2 inches tall. That translates from scale to a human
size of 5' - 5" tall. The Batman figure should be 7-3/16" tall to be
in a proper scale relationship. The vehicle wheel base measures 15
inches and scales out to a 150" real vehicle wheel base. Specifics on
the real DOJ / Justice League Batmobile list a 173" wheel base. Other
pieces are skewed as well. Read some of the online literature that
describe it as 1:10 scale but does not call it a scale model. Good
play on words. Movie correct description is not exactly accurate but
in this case from an eclectic perspective everything looks right. The
cannon seems out of place but after removing everything else blends
well except for the side mechanics which are very shallow.
Compared this vehicle with Mobieus, Jada, Hot Wheels elite, and
photo-images of the Hot Toy's 1:6 DOJ Batmobiles.
SUMMARY:
Mattel 1:10 scale  RC Justice League Batmobile: Excellent RC and
display piece but not that good for a true movie correct build.
The Hot Toy's 1:6 DOJ or final rendition will be the best for a movie
correct build.
Of the scale models currently available, the Hot Wheels Elite 1:18 DOJ
appears to the most accurate scale model and has the best detail and
mechanics. vertigo
I picked one up last Saturday for $134 when Toys R Us had coupon glitch. Probably gonna keep it boxed up just like my 1989 Batmobiles.....
Post #159929
Posted 11/20/2017 8:11:13 PM
Here is a copy of the photo-image that I am currently using as my screen saver.
Outstanding contrast between the image and screen icons. vertigo
ALPHA DOJ.jpg (20 views, 65.74 KB)
Post #159931
Posted 11/21/2017 8:38:16 AM
That is one sweet looking pic.
Just a little update on where I'm at now with this build.
I am considering taking this winter to build a 2'x4' CNC router and see how that works to reproduce more accurate body panels in foam, which I would use as plugs to make fiberglass molds.
The other option is to just get started on the frame as I have a pretty good concept of the chassis construction at this point.
Post #159935
Posted 11/21/2017 4:55:22 PM
Sly
“Just a little update on where I'm at now with this build.
pretty good concept of the chassis construction at this point.”
I hope you choose the frame option.
You will need a place to hang all those body panels. vertigo
Post #159936
Posted 12/13/2017 5:25:40 PM
Any progress on your planning or building? vertigo
Post #160033
Posted 12/13/2017 7:39:53 PM
My daughter is getting married this winter so that is putting a big crimp on the finances. So no progress at this point.
Post #160034
Posted 12/18/2017 4:25:43 PM
Maybe we could build one of these, like this photo-image of the 1989 costume from Rubie's Costume Company, except in a BvS DOJ/Justice League configuration to tide us over until we get the physical builds going.
Post #160051
Posted 12/18/2017 7:31:43 PM
HAHAhahaha
Post #160053
Posted 12/20/2017 5:57:19 PM
sly
"I am considering taking this winter to build a 2'x4' CNC router and
which I would use as plugs to make fiberglass molds."
Here is something that might be of interest to you.
Part Four
3D Pantographs
reality.
Why?
Cost:60,000 plus.
of a router.
scale part in 3D.
plans/Instructions
woodgears.ca/pantograph
Post #160078
«««2021222324»»»
All times are GMT -5:00, Time now is 6:51pm
Execution: 0.938. 21 queries. Compression Disabled.
