«««6465666768»»»
Posted 11/22/2020 9:57:13 PM
Received an email today asking about 3D modeling methods.
This information posted on Wikipedia presents a very good description of the subject.
Part One
Modeling
3D printable models may be created with
computer-aided design (CAD) package
3D scanner
A plain digital camera and photogrammetry software
3D printed models created with CAD result in relatively fewer errors than other methods. Errors in 3D printable models can be identified and corrected before printing. The manual modeling process of preparing geometric data for 3D computer graphics is similar to plastic arts such as sculpting.
3D scanning is a process of collecting digital data on the shape and appearance of a real object, creating a digital model based on it.
CAD models can be saved in the stereolithography file format (STL), a de facto CAD file format for additive manufacturing that stores data based on triangulations of the surface of CAD models.
STL is not tailored for additive manufacturing because it generates large file sizes of topology optimized parts and lattice structures due to the large number of surfaces involved.
A newer CAD file format, the Additive Manufacturing File format (AMF) was introduced in 2011 to solve this problem. It stores information using curved triangulations.
Post #168927
Posted 11/22/2020 9:58:31 PM
Part Two
Printing
Before printing a 3D model from an STL file, it must first be examined for errors. Most CAD applications produce errors in output STL files of the following types:
holes
faces normals
self-intersections
noise shells
manifold errors
A step in the STL generation known as "repair" fixes such problems in the original model. Generally STLs that have been produced from a model obtained through 3D scanning often have more of these errors as 3D scanning is often achieved by point to point acquisition/mapping. 3D reconstruction often includes errors.
Once completed, the STL file needs to be processed by a piece of software called a "slicer," which converts the model into a series of thin layers and produces a G-code file containing instructions tailored to a specific type of 3D printer (FDM printers). This G-code file can then be printed with 3D printing client software (which loads the G-code, and uses it to instruct the 3D printer during the 3D printing process).
Printer resolution describes layer thickness and X–Y resolution in dots per inch (dpi) or micrometers (µm). Typical layer thickness is around 100 μm (250 DPI), although some machines can print layers as thin as 16 μm (1,600 DPI). X–Y resolution is comparable to that of laser printers. The particles (3D dots) are around 50 to 100 μm (510 to 250 DPI) in diameter. For that printer resolution, specifying a mesh resolution of 0.01–0.03 mm and a chord length ≤ 0.016 mm generate an optimal STL output file for a given model input file. Specifying higher resolution results in larger files without increase in print quality.
Post #168928
Posted 11/22/2020 10:53:28 PM
Creating original files in CAD can take many hours to create.
3D Laser Scanners can create usable files in an hour, or so, saving hundreds or thousands of CAD work hours. (Need something that exists in physical world. A model, existing form, or something similar.)
3D laser scans may also be used with CAD to create hybrid or combined files.
3D Scanners
3D Laser Scanning is a non-contact, non-destructive technology that digitally captures the shape of physical objects using a line of laser light. 3D laser scanners create “point clouds” of data from the surface of an object. In other words, 3D laser scanning is a way to capture a physical object’s exact size and shape into the computer world as a digital 3-dimensional representation.
3D laser scanners measure fine details and capture free-form shapes to quickly generate highly accurate point clouds. 3D laser scanning is ideally suited to the measurement and inspection of contoured surfaces and complex geometries which require massive amounts of data for their accurate description and where doing this is impractical with the use of traditional measurement methods or a touch probe.
3D scanner-4.jpg (4 views, 34.84 KB)
3D scanner-3.jpg (1 view, 25.06 KB)
Post #168931
Posted 11/23/2020 6:08:57 PM
So, what file format to choose.
Xometry Europe · Apr 15, 2020
https://xometry.de/en/3d-printing-file-formats-compared-obj-stl-amf-and-3mf/
"STL
The STL (Standard Tessellation Language) file format is the pioneer 3D printing file format. It was invented in 1987 by Chuck Hull, the inventor of 3D printing. Three decades later, the STL file format is still the most widely used and is considered to be the standard file format in 3D printing. This is because, having been around for such a long time, STL is compatible with most 3D CAD software and other software and hardware in 3D printing.
Triangular tessellations (all3dp.com)
One key characteristic of STL is that it saves geometry using tessellations. Tessellation is the process of covering (tiling) a surface with a series of geometric shapes in such a way that there are no gaps or overlaps. In an STL file, a 3D model’s geometry is encoded by numerous triangles covering the model’s surfaces.
For curved surfaces, a large number of arbitrarily small triangles are required to cover the surfaces. However, the larger the number of triangles employed in a model, the bigger the file size.
Another distinguishing characteristic of the STL 3D printing file format is that it only stores geometry data. Other data related to a model such as colour, texture, and material are left out. This wasn’t a problem when printers could only print in one colour and one material at a time. It may still not be a problem if you require a simple prototype. However, with advancements in 3D printing such as multi-colour and multi-material printing, and with the use of 3D printing for producing fully functional, ready-to-use objects, the STL file format may well be on its way out
Pros
Compatible with virtually every hardware and software in the world of 3D printing
Most widely used and shared file format for 3D printing. Millions of STL models are available for easy download online
Cons
Can only store geometry data. Colour, texture, and material data is left out
Level of detail is limited. For example, curved surfaces are approximated
The higher the accuracy of the file, the larger it would be
There may be holes and overlapping triangles in the tessellation as the file format is error-prone. Note that imperfections can be detected and fixed using STL repair tools. This, however, is time-consuming
Scale and units are not specified
Conclusion
In conclusion, we recommend the STL formats for simple geometry and single colour prototypes. "
Post #168933
Posted 11/23/2020 8:06:24 PM
Received an email asking, What 3D printer for around 1,000.oo has the best quality with the largest printing area and volume?
After searching for and studying 3D printers with these parameters I came to the conclusion that the CREALITY CR-10 MAX 3D printer that sells for 999.99 fit these parameters the best.
https://creality3d.shop/collections/3d-printer
Anyone out there have a different 3D printer recommendation for the stated set of parameters?
Post #168936
Posted 11/24/2020 6:24:34 PM
The importance of learning CAD (Computer Aided Design
Think about learning to use CAD with at least familiarity as the cost of admission into being able to use CNC tables (that support plasma cutting, routing, milling) and 3D printers.
This is not a skill that can be learned over night. Quite frankly it takes months and even years to become really skilled and 1-4 weeks (25-100 hours) to be somewhat functional.
Still want to experiment and learn about CAD for free.
Don't run out an buy a pricey program. If you have a computer with windows etc. there in a lot of freeware CAD programs available.
https://listoffreeware.com/best-free-cad-software-for-beginners-windows/#:~:text=LeoCAD%20is%20free%20open%20source%20CAD%20software%20for,features%20to%20satisfy%20the%20need
8 Best Free CAD Software for Beginners for Windows
"Here is a list of best free CAD software for beginners for Windows. Using these CAD software, beginners can learn and create 3D and 2D models without knowing too much about CAD. All of these software are simple and easy to understand for beginners and novice users.
These CAD software are simple, but they do not lack any important feature and also serve advanced features for professional users. To create and design a 3D model, these software provides various base models (Cuboid, Cone, Sphere, etc.) along with various sculpting tools. All of these also let you use a mouse to operate tools that make designing more simpler. Apart from sculpting tools, you also get various view orientation tools to look 3D models from all angles. Once a model gets completed, you can save or export in STL, OBJ, DAE, FBX, etc. files.
My Favorite CAD Software for Beginners for Windows:
LeoCAD is my favorite software because it provides the simplest way to create a 3D model. Plus, it is very simple to understand and to operate that could prove really beneficial for beginners. In it, you also get a lot of predefined models of various different categories which let its users to create a design just by modifying the existing models.
You can also check out lists of best free CAD Viewer, CAM Software, and CAD software for Windows.
LeoCAD is free open source CAD software for beginners. It is one of the simplest CAD software that you can find for free. The main focus of this software is to let new users quickly create a 3D model without needing to know much about CAD and 3D Modeling. At the same time, it also offers a lot of features to satisfy the need of advanced users.
In this software, you get various solid model sections like Animal, Antenna, Bar, Container, Panel, Plant, Vehicle, Wedge, etc. In each section, you get various predefined 3D shapes related to that section. You can easily drag and drop shapes to the canvas and join them through mouse to quickly create a 3D structure. Along with shapes, a Colors window is also present in it to quickly assign different colors to different models.
This software stores all the steps performed during 3D model creation, which you can access from its Timeline Section. Using Timeline Section, you can also move to any previous step or to the next step of the model creation process. This helps novice users to easily produce a design. Besides this, simple tools such as movement, snap, rotation snap, relative transformation, etc. to change model orientation, model position, model angle, etc., are also present in the toolbar. After creating a model, you can easily export the model as 3D Studio, BrickLink, Collada, CSV, HTML, POV_Ray, etc. formats.
In general, it is one of the easiest software to create 3D models for beginners.
Go to their website for other free CAD software programs.
k-3D
3D Slash
Wings3D
3D Builder
FreeCAD
Strata Design 3D
LibreCAD
Post #168941
Posted 11/27/2020 4:58:43 PM
Received an email today, "All that computer stuff is great but most people can't afford CNC programs and cutting and printing machines. I want to build a batmobile but I don't have very much money for the cnc tools. Looks like batmobile building required technology is turning this into a rich guy project."
vertigo, "You could always go old school. Scaling squares, image enlargement projectors, and pantographs."
Part Four First posted 12-20-2017
3D Pantographs
reality.
Why?
Cost:60,000 plus.
of a router.
scale part in 3D.
plans/Instructions
woodgears.ca/pantograph
Post #168953
Posted 11/27/2020 5:40:30 PM
Built my 24"x48" CNC router from scratch and it wasn't very expensive. Biggest expense was the electronics. If you do a DIY table it will be a fraction of the cost of a commercial table.
Post #168955
Posted 11/29/2020 10:25:16 PM
More and more, custom and short run car model makers are using 3D printers to produce 1:6 and larger models.
Complete models, dioramas, parts, assemblies, etc.
Post #168962
Posted 12/3/2020 5:47:40 PM
All 3D Printing Filaments Types Explained: Detailed Guide
How to choose the filament for your next 3D printing project.
Joseph Flynt
by Joseph Flynt
Posted on
August 24, 2019
https://3dinsider.com/3d-printing-filaments-types/
Go to this website for everything you need to know for choosing the right filament for your 3D printer projects.
'Of all 3D printing technologies, Fused Deposition Modelling (FDM) has taken the lead in terms of popularity. FDM printers are cheap, easy to learn, and can be used with a wide range of different filament materials. In fact, there are so many different filaments available today that picking the right one for your project may seem overwhelming.
In this article, we go through even single one of the common FDM filaments, highlight their strengths and weaknesses, and discuss their best applications. We’ll start with the most popular ones and work out way down towards the more obscure and unusual alternatives.
There are a lot of options for 3D printing filaments out there."
Post #168978
«««6465666768»»»
All times are GMT -5:00, Time now is 1:37am
Execution: 0.125. 11 queries. Compression Disabled.
