«««6263646566»»»
Posted 11/11/2019 8:29:16 AM
Last Login: Yesterday @ 7:55:59 PM
Posts: 3,137, Visits: 4,839
Put 4 more hours on Justice League batmobile bringing total to 93-hours so far on
air intake /hood / top and front of dash board. From my calculations the man hours required to finish these assemblies (100 hours estimate) is approximately 15% of the 700 hours required to finish the body work.
This is my current best estimate but it could run up to a 1000 man hours.
Today I: Completed air intake /hood / top and front of dash board.
Assembled bolts and slats permanently.
Did more layout work on dash board and split canopy window assemblies.
PICT0004 (75).JPG (18 views, 281.38 KB)
PICT0007 (68).JPG (14 views, 222.25 KB)
PICT0008 (66).JPG (12 views, 256.26 KB)
PICT0010 (61).JPG (11 views, 232.84 KB)
PICT0011 (53).JPG (13 views, 303.05 KB)
Post #166934
Posted 11/11/2019 9:05:44 AM
Last Login: Yesterday @ 5:38:15 AM
Posts: 1,553, Visits: 4,756
Looks great. Are you going to go with black then instead of gun metal gray?
Post #166936
Posted 11/11/2019 8:25:15 PM
Thanks for the kind words sly.
I am only using flat black primer until I have completed the body construction.
Priming of these assemblies is not a final finish preparation but rather a prevention to keep rusting of bare metal at bay.
When construction is completed I will paint everything gun metal gray.
Post #166938
Posted 12/14/2019 9:39:32 PM
Placed a copy of this post here for anyone planning to and/or building a bat vehicle.
Here is the best book ever written on CNC programing/operating systems.
The lathe threading section in particular is extremely well written.
This book is written in easy to understand language and very well illustrated.
I bought the hardback copy because I like to make ink and highlighter marks and notations.
No other book covers CNC control setup in such practical detail. This unique reference from the author of the best-selling CNC Programming Handbook features nearly all of the activities a typical CNC operator performs on a daily basis. Starting with overall descriptions and in-depth explanations of various features, it goes much further and is sure to be a valuable resource for anyone involved in CNC.
Describes working with all types of offsets for milling and turning applications, interpretation of part programs, applying trial cuts, making program changes, and much more.
Places emphasis on troubleshooting many common problems that occur in CNC operations.
Presents suggested methods of correction, along with methods of prevention.
Post #167992
Posted 12/15/2019 5:21:15 AM
Checking it out.
Post #167995
Posted 1/10/2020 7:15:18 PM
Placed a copy of this post here for anyone, planning to and/or building a bat vehicle.
Business and travel demands have kept me away from my Tumbler and Justice League builds. Hope to be back to my builds sometime in late January or early February. Read an excellent book while traveling.
MACHINING for dummies by Kip Hanson
ISBN: 978—1-119-42613-4 copyright 2018
The book is a very well written, 300-page, progressive history/review/summary from past to present covering machine tools, simple and complex metalworking and other materials processes, CNC programming, G-code, computer software, robotics, etc.
I would describe it as the best tool and process summary I have read.
The material is relevant to the building of most parts and assemblies in today’s world.
Post #168042
Posted 1/10/2020 7:29:09 PM
Ah! good to see you old friend. I was just complaining that this place seems dead without your contributions.
Post #168043
Posted 1/16/2020 7:04:41 PM
Here is a great deal from Grizzly on a 24" x 60" (2 x 5 feet) CNC routing table.
The CNC Shark HD5® w/ Extended Bed is a new, and extraordinary, must-have tool for any sized shop. The CNC Shark HD5® will handle all your machining needs, whether it’s in a home shop environment or on the production floor. The HD5® comes standard with everything you need to quickly get it set up and running: the latest version of Vectric VCarve Desktop design software, a color pendant controller, 2 hold down clamps, carbide... View More Details
Buy Now! Sale Ends 1/31/2020
$4,499.99
+$99.00 Freight
List Price: $4,999,99
You Save: $500.00 (10%)
Check Shipping Availability
The CNC Shark HD5® w/ Extended Bed is a new, and extraordinary, must-have tool for any sized shop. The CNC Shark HD5® will handle all your machining needs, whether it’s in a home shop environment or on the production floor. The HD5® comes standard with everything you need to quickly get it set up and running: the latest version of Vectric VCarve Desktop design software, a color pendant controller, 2 hold down clamps, carbide V-bit, and NWA's exclusive, patented Virtual Zero Unlimited software. Built with industrial grade components, the CNC Shark HD5® also features a HD aluminum and steel reinforced gantry, a new extruded aluminum router mount system, interlocking aluminum table, linear rails and guides on the gantry, and anti-backlash, wear-compensated lead screws on all axis. The HD5® is the perfect tool for carving or machining a large variety of projects made from wood, soft metals, composites, or plastics. The HD5® is fully compatible with NWA's extensive product line of additional accessories, such as laser, 4th axis, scanner, and more. The CNC Shark HD5® is made in the USA, comes with a full one-year warranty and includes lifetime technical support so you can buy with confidence.
Specs and Features
• Exclusive PATENTED NWA Virtual Zero software that, when used together with the CNC Shark touch plate, (Sold Separately) "maps" the surface of your table or workpiece, using the map as a dynamic reference point. This eliminates problems caused by warped boards, or inconsistencies in the table, which often occur when clamping pressure is applied. It also opens up untold creative potential when working with 3D work pieces. Link will be emailed on purchase. $199 value
• Colored touch screen pendant controller
• Includes the latest edition of Vectrics VCarve Pro design software - $699 Retail value
• Ready2Control, a computer control panel software featuring start, stop, and go to G-code location as well as project queuing for reliable bit change applications. $149 retail value
• Vector Art 3D Sampler Pack. $99 retail value
• X & Y homing capability
• Table dimensions: 28" x 63"
• XYZ travel: 25" x 50" x 7"
• Overall dimensions: 36-1/4" W x 63" L x 24-1/2" H
• Linear guides and bearings on the gantry
• Anti-backlash, wear-compensated leadscrews on all axis
• Interlocking rigid aluminum table with virtually unlimited clamp positioning
• Aluminum gantry backplate for heavy machining capabilities.
• Aluminum router mounting clamp
• Steel encased gantry legs for increased rigidity
• Automatic router on and off control
• USB interface
• Compatible with the following routers (sold separately):Bosch 1617-18; DeWalt 610, 616, 618; and Porter Cable 890 Series
Post #168065
Posted 1/17/2020 8:53:42 PM
sly,
"The reason I use an up spiral bit is that it throws the cut material up to the top where the dust collection vacuum removes it. Even with that the foam makes a lot of dust, and it's statically charged so it sticks to EVERYTHING."
Hey sly,
Ever think about fabricating a machine enclosure to control most of the dust.
You could build your self one for 1-200.oo.
Here is the information on the enclosure for the HD5 Shark that go for 600.oo
The CNC Shark Enclosure is designed to help control dust, add safety, and reduce machining noise. Made from Aluminum, Plexiglas and all steel connectors, the CNC Shark Enclosure is designed to give years of service. Convenient hinged access door with magnetic catch allows for easy material removal or bit changes. Pre-drilled 3” hole for cords allows for the case to be placed on any flat surface. The CNC Shark Enclosure works well for schools, trainers or anyone needing additional safety during demonstrations. Fits all CNC Shark HD Models except Slim Line or HD extended, also fits older Pro and Pro Plus models as well as it can also be used with CNC Piranha XL
Post #168078
Posted 4/17/2020 9:43:36 PM
Motors for Makers: A Guide to Steppers, Servos, and Other Electrical Machines 1st Edition
by Matthew Scarpino Scarpino (Author) 21.99 from Amazon
This is an excellent book for anyone interested in acquiring a working knowledge of the stepper and servo motors
used in CNC machines and other applications, as well as, most other types of electric motors.
It is written in easy to understand language aimed at persons who want to acquire a practical working knowledge of electrical motors without too much jargon and theory.
It is written for persons who use machines, powered and/or controlled with electric motors and/or for others
who are planning to use electric motors in their projects.
It is not a book about how to build motors. vertigo
Post #168449
«««6263646566»»»
All times are GMT -5:00, Time now is 11:39am
Execution: 0.203. 13 queries. Compression Disabled.
