Posted 10/20/2019 9:05:26 AM |
Put four more hours on Justice League batmobile. 44-hours so far on air intake /hood / top of dash board.
Cut, fitted, and clamped front panel parts of dash board assembly.
Posted 10/21/2019 6:16:52 PM |
Put three more hours on Justice League batmobile. 47-hours so far on air intake /hood / top of dash board.
Welded front panel parts of dash board assembly.
Posted 10/22/2019 6:01:01 PM |
Put three more hours on Justice League batmobile bringing total to 50-hours so far on
air intake /hood / top and front of dash board.
Carefully measured for location of parts and clamped or fixed the assemblies in place.
Next I will lay out and fabricate top pieces for these assemblies in similar fashion as seen on attached
photo-images of the model.
Posted 10/22/2019 9:04:33 PM |
You are moving along quite nicely.
Posted 10/27/2019 6:39:25 PM |
Put 8 more hours on Justice League batmobile bringing total to 58-hours so far on
Laid out and cut 22 metal pieces for these assemblies in similar fashion to those as seen on attached
Next step:
Grind and clean up edges on these 22 metal pieces.
Drill 10 holes in each of these 22 metal pieces for blind welding these pieces to the other assemblies.
Or maybe, use 1/4" diameter hex head bolts to secure the 22 metal pieces to the other assemblies to give
more importance to the assemblies look.
Posted 10/27/2019 7:12:24 PM |
Interesting look. Again, quite different than the DOJ version. This is an area of the car that we don't have a 3d file of so will need to be fabricated from scratch, like yours.
Posted 10/27/2019 7:41:57 PM |
The 1/6 Hot Toys DOJ batmobile that they displayed at several shows had some images posted on line that show it with the two halves of the window assemblies open and raised. The dash top area can be seen in those images.
Also read that the Hot Wheels Elite DOJ is very close in their modeling of the interior.
Posted 10/27/2019 8:28:51 PM |
FOUND THE IMAGE IN MY FILES. Not the highest resolution.
Will look for a higher resolution image.
Posted 10/27/2019 8:42:46 PM |
Here is a higher resolution image.
Posted 10/29/2019 6:50:44 PM |
Here is a high resolution photo-image of the dash top area of the Hot Wheels Elite DOJ batmobile.
You can enlarge it up quite a bit without loosing useable resolution.
Perfect to blow up to a life size photo blowup or to make a file for milling on your CNC table.
I may add a few of the features to my Justice League.
