«««5556575859»»»
Posted 9/14/2019 9:22:34 AM
Last Login: Yesterday @ 7:09:10 PM
Posts: 2,641, Visits: 3,840
sly
"So you're going to do a two seater and eliminate the cannon?"
Might build the cannon as a plug in module.
Will you keep all the other armaments?"
At this time yes.
Might modify the two upper rocket arrays that are attached near the air intakes.
Even looking at making the two top mounted chain guns into an internally hidden pop up system.
Post #165695
Posted 9/15/2019 10:55:44 AM
Update:
Completed translation of wood proxy firewall plate into metal.
Completed cutting, fitting, clamping and welding on additional flat panel parts and welded edges to main frame.
Next I will:
Cut, fit, clamp, and weld in structural elements to firewall.
Still need to cut, fit, clamp, and weld additional elements to main roll bar.
Will be using the passenger compartment as my working center point to work from as I fabricate and add additional pieces to my Justice League build. vertigo
PICT0014 (34).JPG (3 views, 394.25 KB)
PICT0009 (41).JPG (3 views, 386.27 KB)
PICT0010 (42).JPG (3 views, 363.85 KB)
Post #165699
Posted 9/16/2019 7:34:36 PM
Spent 4-hours today cutting metal pieces for firewall and main roll bar assembly.
Welded in bottom panel to bottom of firewall.
Still have more pieces to weld to firewall.
Plan to complete fire wall, roll bar assembly, and passenger compartment floor before
cutting openings as needed for engine/transmission, etc.
PICT0006 (50).JPG (4 views, 338.71 KB)
PICT0007 (47).JPG (4 views, 380.51 KB)
Post #165704
Posted 9/17/2019 12:09:23 PM
Last Login: Today @ 4:53:19 PM
Posts: 1,179, Visits: 3,137
Ah, I was wondering about that. Looks like you're moving pretty quickly now.
Post #165707
Posted 9/17/2019 6:38:20 PM
Spent 4-hours cutting, fitting, and clamping metal pieces to firewall in preparation for welding.
PICT0009 (43).JPG (4 views, 295.75 KB)
PICT0012 (38).JPG (3 views, 260.73 KB)
PICT0005 (53).JPG (4 views, 300.27 KB)
PICT0001 (51).JPG (2 views, 311.29 KB)
PICT0003 (51).JPG (1 view, 296.26 KB)
PICT0004 (52).JPG (3 views, 314.91 KB)
Post #165708
Posted 9/17/2019 6:56:58 PM
Love the updates. Looking forward to seeing how you do the roll bar.
Post #165709
Posted 9/18/2019 7:05:41 PM
Spent 4-hours cutting, fitting, and clamping additional metal pieces to firewall in preparation for welding.
Tack welded all these pieces together and began to make complete welds.
Cleaned up around build.
Took photo-images of total build from distance and closer images of firewall work.
The photo-images from distance give some feeling of the builds personality. vertigo
PICT0001 (52).JPG (10 views, 359.00 KB)
PICT0004 (53).JPG (7 views, 343.95 KB)
PICT0010 (45).JPG (9 views, 360.83 KB)
Justice League-1 (2).jpg (4 views, 189.55 KB)
Post #165712
Posted 9/19/2019 10:58:33 AM
Last Login: 2/24/2020 1:55:03 PM
Posts: 57, Visits: 208
The rear "firewall" looks quite tall, ね?
Looks good though.
-Waz
Post #165715
Posted 9/19/2019 11:44:31 AM
WAERZENGINEER,
"The rear "firewall" looks quite tall, ね?"
The tall back panel is the rear wall of the passenger compartment.
May end up taking a few inches off the height. vertigo
Post #165716
Posted 9/19/2019 7:00:41 PM
Really like the impression of the distance picture.
Post #165717
«««5556575859»»»
All times are GMT -5:00, Time now is 10:26pm
Execution: 0.312. 16 queries. Compression Disabled.
