Posted 12/28/2018 6:22:01 PM |
After reading this post I have done a little research on the 4th axis idea and it looks like it would be pretty easy to add one to my existing set up. As you know, the software already supports it. The electronics package I bought for my machine already has it integrated into that as well. So, looks like I would just need to get the rotary table and fasten it on to the front of my machine with the proper drive motor and I would be in business!
Posted 1/30/2019 6:34:21 PM |
The Batman’ To premier In Summer 2021; Ben Affleck out as Batman
EXCLUSIVE: Warner Bros. is dating their next rendition of Batman for June 25, 2021.
A search is underway for a younger actor to play the new Dark Knight.
News is The Batman will not be based on Frank Miller’s Batman: Year One comic.
Some are speculating that "The Batman" will be totally non-related to Affleck's Batman.
SOUNDS LIKE BATMAN WILL BE GETTING A NEW BAT MOBILE.
Posted 1/30/2019 7:24:14 PM |
Did a little research on the web.
Interesting article:
The Batmobile of DC's Titan's universe revealed Nov-16-2018
"Tim Burton's Batmobile is a Major Influence
The indelible mark left on the Batmobile debuted in 1989's Batman is still visible although a bit more rigid in its lines front to back, the design seems to evoke both the Batman film and the more art deco Batman: The Animated Series Batmobile. Until we get a closer look at the front, though, it will be hard to draw that line."
also a
concept photo-image from a French on line newpaper
Posted 1/30/2019 8:05:58 PM |
Visits: 845
The first one has too much schumacher crapmobile also mixed in, and the other two are lame renditions of TAS... So unfortunate wb execs suck so bad at managing the DC movie stuff.
Posted 1/31/2019 9:12:27 AM |
Episode 7 got a tiny, blurry glimpse of the batmobile in the batcave. It was close to the 2nd one there. I think the first one looks like a child's toy.
btw, the fight sense in titans are pretty good but the story lines are a bit boring. The end of season 1 shows Dick/Robin/Nighthawk dreaming/hallucinating a scene where Batman kills several GCPD members in a tunnel. Of course you don't get a good look at Batman but the suit and cowl he's wearing look like cheap Halloween costumes.
Posted 2/28/2019 8:22:18 PM |
Finally, back at my home base.
So, started back on my batmobile and Tumbler builds today.
Decided to work on the steering wheel.
Completed preparations on back of steering wheel for metal backing plate.
Started sealing cracks and holes in preparation of resin pour to fill inside voids.
Posted 3/2/2019 3:38:54 PM |
I will be anxiously waiting to see how this turns out.
Posted 3/2/2019 4:33:56 PM |
Here is a copy of my drawing for the backing plate on my DOJ/Justice League steering wheel.
Posted 3/5/2019 5:39:19 PM |
Spent a few hours on DOJ/Justice League steering wheel.
Cut out back plate (still needs some more shaping and grinding.)
Machined the main hub to specifications of a 2" universal system.
This allows the use of universal 2" adapters, fabricated 2" custom adapter(s), and solid or hollow 2" tube shafts.
Posted 3/9/2019 5:38:45 PM |
From near the start of having the DOJ/Justice League steering wheel identified by "THEMAN", studying photo-images and examining the real plastic steering wheel I guided my progress from mostly one question.
How could a plastic video game simulator steering wheel be modified enough to be used to drive the real DOJ/Justice League batmobile.
Finished grinding the back plate to shape.
Welded the 2" adaptable collar onto the back plate and ground the welds.
Used a 4-1/2" angle grinder with a light touch to slowly grind off all plastic protrusions on the back of the plastic steering wheel.
After fitting the back plate to the back of the plastic steering wheel, coated both with silicone gasket compound.
Placed the center bolt through the steering wheel and steel back plate and tightened down.
