PROJECT: CHAMPMOBILE
«««45678
PROJECT: CHAMPMOBILE Expand / Collapse
Posted 11/20/2018 5:26:04 PM
Last Login: 1/10/2019 4:37:04 PM
Posts: 53, Visits: 303
My goal was to have this California register-ready by year end so I could be at the DMV January 2 to get my paperwork....but every single step on this project is an ass kicker
by connecting a switch straight to the starter, I had the biggest win of the project thus far, which was getting the engine running. It runs rough because not everything is connected with the vacuum lines etc, but sounds beastly, especially with the cat back exhaust...so we grabbed a body harness and connected the ignition, but it just will not start. we have power all the way through to the tail lights and climate control etc, but it just wont start.
After going to multiple junkyards and trying a few things, its still not starting from the ignition....after losing months and avoiding the soul crushing expense of paying someone to fix it all up....I decided to switch gears and deal with it later..we are going to work from the rear of the car and push forward.
The body itself wasnt put together with great care...and there are flaws, particularly with the rear fenders...which was placed in a way that forces the rear end of the fender to be angled to the outside, and the bottom of the fender to not be a straight, horizontal line. most noticeable on the passenger side rear....The wheel well is also an inch smaller than the driver side. we added in some wheel tubs which helped buff out the rear end and made it a lot sturdier
We have been fitting in some bracing to push the lower edges of the body out, and others to push the body inwards, and it really made a difference. I got a space heater I will use for my afterburner, and we have been experimenting with that. All progress pics actively updated on my online photo album
Right now our priority list is:
- Exhaust done (extend exhaust to correct position, make plates, polish up tips, weld it up, black chrome dip)
- put in side walls of trunk, which will also act as an anchor for body bracing and a place to mount supports for trunk lid
- add rear support bar which will act as a bumper and will support after burner
- plate in rest of trunk
- build out weather stripping/gutter for trunk lid and build trunk latch and hinges
- add tail lights
- rear camera
- reverse light
- cut out vents on trunk lid, add mesh grid
NEXT UP
- body mounts
- finish gas tank area; seal it in.
- CANOPY!
- DASH
- IGNITION!
- HOOD
- HEADLIGHTS
- FRONT INTAKE
Post #161324
Posted 11/21/2018 4:59:22 PM
Last Login: Today @ 3:07:59 PM
Posts: 844, Visits: 1,912
Looking through your picture montage you've made quite a startling improvement to the body line of this car!
Post #161328
Posted 11/22/2018 2:03:41 AM
thanks! it needs a ton of work but its coming along
Post #161338
Posted 1/2/2019 3:28:12 PM
Last Login: 1/19/2019 7:01:53 AM
Posts: 40, Visits: 128
Great job.  Coming along very nicely.
Post #161535
«««45678
All times are GMT -5:00, Time now is 3:28pm
Execution: 0.078. 13 queries. Compression Disabled.
