«««2223242526»»
Posted 12/20/2017 5:27:17 PM
Last Login: Yesterday @ 6:04:10 PM
Posts: 1,819, Visits: 2,710
Part Two
History and General Use
Wikipedia
If you don’t know how to use a pantograph or need a general refresher
go to Wikipedia for a quick read and to see some animations of the
tool in use.
Thousands of articles are found on the internet covering every aspect
of the pantograph.
Thousands of videos are found as well, covering history, use, and
construction of pantographs, including the 3D carving pantographs.
Link to sample video: How to draw bigger and smaller with a pantograph - YouTube
https://www.youtube.com/watch?v=6ph5VPuhO9s
Post #160064
Posted 12/20/2017 5:34:22 PM
Part Three
Availability
Don’t underestimate the pantograph. It is capable of holding an
accuracy of .010 with a good tool under the control of an experienced
hand. A few are accurate to .001.
Invented in 1604 by Christoph Schiener it is still commonly used
throughout the modern world by many thousand times more people than
the computer drafting programs and is found in even the most
under-developed countries.
For accurately enlarging and reducing drawings they can be purchased
for as little as 14.95 at Hobby Lobby and 39.99 at Office Depot. The
Alvin Pantograph item # 584320 from Office Depot is of sufficient
quality to draw most enlarged templates. Very sophisticated drawing
pantographs with ball or sleeve bearings can be purchased for less
than a thousand. There are pantographs that can hold small hand
grinders and routers. There are also 3D pantographs than can carve
enlarged copies from small models.
There are thousands of free plans on the internet to build simple
pantographs to the more complex 3D motorized carving pantographs.
Surplus industrial pantographs are still found for sale online, at
eBay and many other auction sites.
Post #160069
Posted 12/20/2017 5:48:06 PM
Part Four
3D Pantographs
reality.
Why?
Cost:60,000 plus.
of a router.
scale part in 3D.
plans/Instructions
woodgears.ca/pantograph
Post #160074
Posted 12/21/2017 5:16:12 PM
Part Five
Summary Steps
Making 1:1 life size or other scaled drawings and templates. (Usually
used for flat parts)
Step One: Create drawings for each part from your scale model accurate
to the models scale that you want to make a scale enlarged drawing and
template from. Most Bat Vehicle models will be 1:18, 1:24, 1:25, or
1:6. Think of scale models as pictorial blue prints that contain
summarized representations of reality. The more detailed the model the
more information it contains. Scaling is both reference parameter and
potential.
Step Two: Scale up your drawings in steps to lessen the problems
associated with exaggerated errors that are due to slight variations
in measurement and tracing stylus control.
Scale up in steps. First use the pantograph to scale up your model
scale drawings 1:18, 1:24, 1:25 to 1:6. Clean up the edges, straighten
lines, smooth curved lines, and match up intersections.
Next use the pantograph to scale up your 1:6 drawings by three to 1:2.
Clean up the edges, straighten lines, smooth curved lines, and match
up intersections.
Next use the pantograph to scale up your 1:2 drawings by two to 1:1.
up intersections.
Step Three: Use these 1:1 drawings by transferring them on to stock
material and cut out your parts. You could also make a more robust
template then use it to mark your material.
3D Carving/Routing Pantograph
Step One: Fasten model or model part to table securely to prevent all movement.
Step Two: Fasten wood, foam, plastic or other media to table securely
Step Three: Follow model or model part with stylus.
Seems simple but the feedback systems are in fact much more complex
than the CNC because it is physically operated with a human brain
neuro-physical interface. The CNC can do a great job making accurate
parts but the costs are generally prohibited to individual ownership.
But, other than cutting itself off when it runs into something the CNC
lacks much sophistication in feedback response. On the other hand, the
drawing and 3D carving/routing pantographs have the ability to respond
to the creative eye and hand of the artist at any moment. Near
infinite feedback allow variability in speed, trajectory, track, etc.
and allow artists to finesse their work. Master statues and other art
masters, even the minting masters of coins, are done using a drawing
and/or carving pantographs. Once the master is created it is then
programmed with CAD and mast produced on CAM CNC machines.
For Bat Vehicle building we would prefer CNC but cost prices most of
us away from the benefits. However, the pantograph technology born in
early 1600s still works very, very, well and costs on average less
than one quarter of one percent (1/400th) of the cost of CNC. The
drawing and carving pantographs are not obsolete but still are the
majority norm for enlarging and reducing drawings and 3D forms.
Post #160083
Posted 12/25/2017 6:27:15 PM
Was looking at a toy batmobile Tumbler, a Mattle part # Y4629, the first I bought at Walmart and original inspiration for my Tumbler build. These are now frequently found on eBay for 10-15.oo. One early replica build of the Tumbler I am told made extensive use of this toy. Some interesting observations can be made from looking at this model. The toy's pictorial information is skewed and simplified, but still carries the majority of the key informational characteristics in its eclectic presentation. The clamshell access to the interior is made from the front window assembly and part of the roof as a combined unit. And finally, this toy is an excellent example of mechanical morphing as demonstrated by the pop out hidden rocket launchers. An inexpensive piece worth studying for both characteristics and inspiration. vertigo
PICT0001 (33).JPG (1 view, 199.91 KB)
PICT0007 (31).JPG (0 views, 196.01 KB)
PICT0010 (30).JPG (1 view, 190.27 KB)
PICT0012 (26).JPG (1 view, 189.41 KB)
PICT0013 (26).JPG (1 view, 205.30 KB)
PICT0015 (22).JPG (1 view, 199.42 KB)
Post #160099
Posted 12/28/2017 5:53:15 PM
Rigidity in thought has taught us to visualize and believe that a CNC
plasma cutting and wood/form router system looks like a table with two
rails that a boom rides on to create X and Y axis.
This company clearly was thinking outside the box when they created a
CNC system with an effective cutting range of 5.2 X 9.8 feet that
sells for 2,458.00. Looks like one would only have to add a deep Z and
build a wood framed table to have an excellent foam cutting table.
Will be researching this possibility further.
Portable CNC Cutting Machine with THC and Supporting Oxyfuel and Plasma Cutting
Amazon Price: $2,458.00 & FREE Shipping Effective Cutting Range: 5.2
x 9.8 feet
Effective Cutting Range: 1600x3000M(5.2x9.8ft).
Effective rail width(X axis): 2.2 m (7.2 ft) .
Effective rail length(Y axis): 3.5 m(11.5 ft) matching.
Flame(Oxyfuel) Cutting Thickness: 5-150MM, Max. 200MM.
Supporting Cutting: Flame(Oxyfuel) and Plasma(Plasma Arc Cutting Equipment).
Flame(Oxyfuel) Cutting Gas: LPG/Coal gas, Propane, Acetylene.
Plasma Cutting Thickness: 80amps(1-8mm Piercing Cutting),
100amps(1-12mm/15mm Piercing Cutting).
THC including - Automatic Plasma Torch Height Control.
Flame torch assembly being including.
StarCAM nesting software with Softdog being including.
other necessary accessories.
Note: Does not including Plasma Equipment and Plasma Straight machine torch
Post #160108
Posted 12/31/2017 9:54:59 PM
A good use for this machine would be to cut metal Tumbler parts from wood templates.
These are also used with routers, sabre saws, and rotary saws to make wood, plastic, foam, plastic, and to cut parts from pre-cast plastic resin panels.
The Oxygen/Acetylene cutting torch was invented in 1903 by Edmond Fouche and the Oxygen/acetylene Cutter Tracer Duplicator Pantograph was in use by 1904. After the invention of the plasma torch it quickly became interchangeable with the oxygen/acetylene torch.
This tool is still in wide use throughout the world and is much more commonly used than the CNC plasma table. Average cost is 250-300.oo.
Wood patterns are used for short production runs and metal patterns for long runs.
Here is a typical example found on Amazon.
Rotten Leonard's Jalopy Shop Plasma Cutter Tracer, Pantograph
New (1) from $275.00 + $18.49 shipping on Amazon
• Adapts easily to any hand held plasma torch
• Accepts patterns made from almost any material
• Operates on a 48" radius from the stand pipe (not included)
• Quickly and accurately duplicate parts or designs
• Works on the inside or the outside of patterns.
Now, you can reproduce parts quickly and accurately. A plasma tracer
will save tons of time by allowing you to make patterns out of any
almost any material then cut a finished part from steel or aluminum.
If you ever need to make more than just one part this is the tool for
you. vertigo
Post #160131
Posted 1/7/2018 7:12:04 PM
Currently using this method to do a set of full size Tumbler templates for my Tumbler build.
Converting the pictorial blueprint (scale model) into full size templates with step up grid square method.
Steps
Make scale model size drawings on appropriate grid size paper
Example: 1:6 scale tumbler model grid square paper would measure 1-1/4" squares.
Next step: Use 1/4" plywood and draw 7-1/2" grid squares on plywood to scale up to 1:1.
Multiple all the information in each 1-1/4" times six and record this information into each relevant 7-1/2" square. This method will give you full size templates.
Cut the templates out with a sabre saw and they are ready to use. vertigo
Tumbler Template-A (2).JPG (1 view, 186.78 KB)
Post #160149
Posted 1/8/2018 11:41:02 AM
Bopenstein
"Where did you get the pictures of the panels from?"
They were made by tracing the 1:6 scale Hot Toy's Tumbler model panels.
These were then cut out with a razor knife.
Then these were blacked with a Sharpie black marker.
These were then glued to 1-1/4" hand drawn grid paper.
Then these were used to transfer the images to 7-1/2" grid squared 1/4" plywood sheets.
And that my friend is how you do it 'old school". vertigo
Post #160158
Posted 1/12/2018 6:59:03 PM
Here are a couple of photo-images of a few sample finished full-size templates. vertigo
PICT0001 (36).JPG (0 views, 298.83 KB)
PICT0001 (36).JPG (0 views, 295.98 KB)
PICT0005 (36).JPG (0 views, 264.90 KB)
Post #160182
«««2223242526»»
All times are GMT -5:00, Time now is 2:38am
Execution: 0.109. 12 queries. Compression Disabled.
