«««1819202122»»»
Posted 9/15/2017 2:22:12 PM
Placed a copy of this post here for anyone that may be able to benefit from it planning to and/or physically building a Bat Vehicle.
sly
"I had given up on the idea of milling foam parts from huge blocks of foam because it was too cost prohibitive. But after spidey4fun's post about a guy that was milling car parts from regular foam insulation I started rethinking that idea. Smaller blocks of foam could be milled separately and then assembled together! It doesn't have to be milled out of one huge block with a giant machine.
However, even small CNC machines are expensive. But there are some nice kits out there. I'm seriously considering this one. https://www.buildyourcnc.com/item/cnc-machine-blacktoe-v4-2x4."
Looked at the kit. Very nice for 4,000.oo Have you searched for used machines? Like, Torchmate, Routermate, etc. When I was researching them out I found 2 x 2 and 2 x 4 used Torchmate complete with computer on EBay for 5 and 7,000.00. Biggest problem with all these, and the kits too, is Z axis cutting depth. It usually falls just short of 6 inches. Once I get started on the physical building of my DOJ Batmobile I have plans to convert my 4 x 4 Torchmate by elevating it 2 feet above the bottom cabinet and switching out the automatic Z axis depth height control for a deep cutting Z axis some where in the range of 18-24 inches. Complete CNC foam cutting router tables are also sold online with a deep Z axis already installed. vertigo
Post #159442
Posted 9/15/2017 7:22:42 PM
Used an angle grinder to grind dual shock mount sides to shape, then welded them to a 3/8" thick, 2" wide flat bar. Cleaned up welds with the angle grinder and welded the finished dual shock mount to the U-bar. vertigo
PICT0008 (23).JPG (3 views, 218.53 KB)
Post #159447
Posted 9/17/2017 6:29:17 PM
Proxy Shocks,
Built this pair of proxy shocks to stand in for the real shocks until
my Tumbler is mostly finished. Otherwise, given the non-predictability
of the finished vehicle weight, it would be impossible to get the rear
coil over shocks right.
Cut the two main lengths from a piece of old oil field drill stem I
had laying around and the four end disks from scrap 3/8” steel plate.
After rough welding these to the ends of the main lengths I welded on
some eye bolts. Then I painted them since I will be looking at them
for quite some time while I complete the vehicle.
I have placed a copy of this post here because the concept of using
proxy shocks to stand in for the actual shocks is applicable to any
Bat Vehicle build that uses shocks and this information may be useful
to someone planning to or actually building a Bat Vehicle.
PICT0005 (24).JPG (3 views, 277.87 KB)
Post #159459
Posted 9/18/2017 5:44:36 PM
I placed a copy of this post here because it might be of some benefit
Bat Vehicle Mechanical Problem Solving
The connections between theory and reality
Part One
Those who decide to build a Bat Vehicle will probably face a few major
problem solving challenges such as construction of the Tumblers front
arms and dually rear tires, but mostly a multitude of small problems
will present and have to be overcome.
The solutions to these problems will be found by using Mechanical
Reasoning, a combination of mental simulation and rule-based
approaches.
For mechanical reasoning, the representational material and the
referent is fundamentally spatial due to the science of motion. Motion
is a spatial property. Mechanical reasoning is determined by visual
spatial information such as relational connectivity, shape, and
location of objects.
Mechanical reasoning is often complemented by the conscious occurrence
of an evolving internal mental image set (simulation) of the physical
and relational circumstances.
“In the rule-based approach a sentential or propositional explanatory
representation is a set of facts or universal rules about the
representational material and referent (Hegarty, 2004).”
“While it is commonly accompanied by imagery, mechanical reasoning is
not a process of examining a general visual image in the ‘mind’s eye’.
Instead, mental simulations are structured fragments that include
depictions of non-visible properties and can be utilized in
concurrence with non-imagery practices, such as rule-based reasoning.
(Goldstein, 2011, p. 288).”
Post #159472
Posted 9/18/2017 5:45:34 PM
Immersive Mechanical Problem Solving
A branch in the field of Immersive Learning
Part Two
Immersive Mechanical Problem Solving:
Once the Mechanical Problem can be described in a statement of the
problem, the individual or team of individuals attempting to solve the
problem is/are placed in a room with all the physical elements related
to the problem.
I used a similar method to solve the problems related to my design and
execution of constructing my Tumbler’s front arms and rear suspension.
When I started, I made an agreement with myself that I would spend an
hour a day building on my Tumbler and that if I wasn’t building
(Builder’s Block) that I would sit for that hour in the presence of my
Tumbler. This has worked well for me to solve my mechanical and
construction problems. When I sit in the presence of my incomplete
Tumbler build and the surrounding tools, parts, steel, and other
materials, I always find something inspiring in these that drive me
forward. I keep a little sign near my Tumbler that reads, “JUST DO
SOMETHING”   My motivation for building the Tumbler has never
faltered.  vertigo
Post #159473
Posted 9/19/2017 5:38:38 PM
Built by New Deal Studios, the 1/3 scale radio control filming model.
New Deal Studios is a 21st Century Creative Studio known for creating
Visual Effects for such films as the DARK KNIGHT series, HUGO, THE
AVENGERS, SHUTTER ISLAND, INCEPTION, and INTERSTELLAR.
Post #159480
Posted 9/20/2017 6:54:28 PM
I placed a copy of this post here for the benefit of anyone that might
be able to use this information in planning and/or building a Bat
Vehicle.
I received an email the other day stating, “I can’t weld and I have
never worked with metal. I have worked in the past a little with wood
in junior high shop class. How could I ever be able to build a
Tumbler?”  This is a good question that opens the door to the building
concept of TRANSLATION.
TRANSLATION
The conversion from one form or medium into another. The process of
moving, something from one place to another. In this case we are
talking about the movement of information.
If one builds a Bat Vehicle in wood they have stored a vast amount of
spatial and conceptual information in the wood parts. The wood parts
will contain the summaries of evolutionary eclectic mechanical problem
solving, relational connectivity, multi-dimensional shape boundaries,
and other representational information. (parts with three dimensional
measurements and their relationships with other three dimensional
parts.)
TRANSLATION occurs when we convert or copy the information held in the
wood parts to some other media such as metal, fiberglass, or other
material.
So, someone that builds a Bat Vehicle in wood, but who, has no skills
in metal or fiberglass can hire others that do, to do their
translations into metal or fiberglass.  vertigo
Post #159488
Posted 9/25/2017 8:04:47 PM
All the major Batmobiles from the comics, serials, TV series, movies, and video games have replica toys made from them. Some literally have hundreds. These can be excellent resources for the Bat Vehicle builder.
Toy departments in stores and online are excellent places to find many
unique artistic expressions of representational ideas from
unconstrained minds.
Free from the chains of conservative artistic expectancy found in the
real world, they are in a unique position to explore beyond the
boundaries into the realm of skewed imagination.
This year I have noticed a resurgence of interest in the 1941
modernized Batmobile as expressed in toy car and conceptual art.
See attached photo-images of 1941 Batmobile toy car currently selling
on Amazon for 29.00 and original 1941 car.
 14” X 6.5” X 6”
Batmobile 41.jpg (4 views, 60.44 KB)
Batmobile 41-2.jpg (2 views, 62.62 KB)
Batmobile 41-3.png (3 views, 438.53 KB)
Batmobile_New_52 (1).png (3 views, 905.26 KB)
Post #159501
Posted 9/26/2017 6:27:46 PM
I place a copy of this post here for the potential benefit to anyone
Building Positional Welding Jigs to Improve Your Bat Vehicle Fabrications
When building without a jig, one relies on a tape measure, clamps,
eyeballs, levels, and shims; great results can be achieved this way,
but it requires skill and patience. With a jig, the parts in a
fabrication are held rigidly in the correct location. If everything is
cut to the right size, assembly simply becomes a game of putting
everything in the jig and welding it together. The benefits for any
fabrication in volume should be obvious.
But, even in one-off Bat Vehicle fabrications, positional welding jigs
can provide advantages that more than make up for the time spent
building them.
Most all positional welding jigs are used hold two or more parts in a
combined rigid position for welding.
Positional welding Jigs are not particularly difficult to construct
and vary from very simple (a few minutes to build) to very complex
(many hours to build).
Jigs aren't necessarily the solution to every Bat Vehicle fabrication
problem, but they are an under-appreciated approach that should be a
mainstay in the tool kit of more DIY builders.
A master welder when welding is rarely found holding anything but his
electrode holder (arc) or wire feed gun in one hand (mig) while
steading it with the other hand! If it isn’t clamped or jigged up he
usually does not weld it. I try to do my welding by these words.
(Note: My Tumbler front arms, axles, and brackets were positioned and
welded with several jigs to a relational accuracy of around 0.010.
Without using positional holding jigs and tactical welding techniques
I could never have obtained such accuracy.)
JIG-5 (1).jpg (3 views, 79.79 KB)
Post #159505
Posted 9/26/2017 9:25:40 PM
Posts: 254, Visits: 3,355
What's the go with copyright on building the tumbler. I'm pretty sure you only have to change it 10% so I'm wondering if just the way the engine has to be set up with a V drive is enough. Or should the body be altered a little bit ( which I don't want to do )
Post #159516
«««1819202122»»»
All times are GMT -5:00, Time now is 8:25am
Execution: 0.219. 12 queries. Compression Disabled.
