«««3132333435
Posted 7/25/2020 9:44:14 PM
Last Login: Today @ 10:21:47 AM
Posts: 2,697, Visits: 4,063
Purchased this useful tool last week.
WARN 885000 PullzAll Corded 120V AC Portable Electric Winch with Steel Cable: 1/2 Ton (1,000 lb) Pulling Capacity.
Price: approximately 200.oo
No load line speed:13.8 fps
Lifts or pulls up to 1,000 lbs.
Replaces old fashioned come-a-longs and chain falls.
Variable speed control trigger with an electronic load limiter with LED indicator
Maximize the amount of work one person can do
Post #168697
Posted 7/26/2020 2:27:17 PM
Last Login: Today @ 12:29:48 PM
Posts: 1,285, Visits: 3,630
Oh, that will be valuable. I will need to get something like that soon to put the body on a trailer and take it to THEMAN. Full fiberglass body is going to be quite heavy.
Post #168699
Posted 7/26/2020 7:28:02 PM
I got mine in the AC model.
There is also a battery pack operated model for twice the price but for a tool that would be little used I can't see the 400.oo cost. Plus battery packs have limited lives and the ones for this tool can not be used with any other tools.
Would have been great if the battery model had been set up to take 20V Dewalt battery packs.
Post #168701
Posted 7/26/2020 7:31:01 PM
sly
"Oh, that will be valuable. I will need to get something like that SOON to put the body on a trailer and take it to THEMAN. Full fiberglass body is going to be quite heavy."
How far away is soon? vertigo
Post #168702
Posted 7/27/2020 5:47:09 AM
Shooting for the end of August, but that might be a little tight. More likely September.
Post #168703
Posted 7/29/2020 9:41:05 AM
Last Login: 9/14/2020 5:06:04 AM
Posts: 134, Visits: 812
Here is a cool little tool I found for making beads for radiator hoses or cold air intakes etc it’s a bit pricey $579 on eBay but works great high quality tool
Post #168707
Posted 7/29/2020 12:05:43 PM
I always wondered how that was done.
Post #168708
Posted 9/15/2020 2:34:21 PM
sly
"The biggest problem is the decorative lines. Some of them didn't come out well. I need a way to make them all equal. I tried making a sanding jig out of a block of wood but it didn't work to well. Might work better if I make it out of aluminum.
Any ideas?"
How about gluing, riveting, and/or screwing square plastic, rubber, or aluminum (square tubing or solid stock) to the inside of the mold.
This should allow you to mold in the decorative lines. My preference would be plastic or rubber.
You can buy square rubber or plastic molding for window glazing with an adhesive peel and stick backing.
If you need to curve the plastic/rubber moldings you can use an electric heat gun.
For aluminum, a propane/Mapp gas torch. vertigo
Post #168773
«««3132333435
All times are GMT -5:00, Time now is 1:19pm
Execution: 0.359. 14 queries. Compression Disabled.
